Root I have a problem
Hello, i recently bought HTC tattoo. Before few days i rooted it, then installed custom ROM. Before doing that i did nandroid backup, but later on i accidentally formated sd card. How i can get back to factory reset ? The mod i installed is CM6, and it seems that theres no factory reset key on that cm6 mod.. thanks.
And I also have another question :)
After i installed CM6 mod, pc and phone wont sync.. Maybe this is because of different versions of sync soft ? On pc there for 1.6 which came with phone, and CM6 mod has 2.2 as i understand. I was looking to download a sync soft for 2.2 for my tattoo but couldnt find.. only for hero,desire and some other models. So now i cant install any apps, also market doesnt work for me.. When i try to access it nothing happens. Im really desperate. Please help me, thanks :)
Hi outbreak3377
If u r trying to get back to the original 1.6 htc sense User Interface then you can get that here:
Index of /shipped/Click
!!!!WARNING!!!!
Make SURE you download the correct one... gsm and cdma versions are different aswell as languages
