I have a Transparent Notification Bar by mistake
mrnict
I guess this works if anyone wants to get a transparent notification bar or if anyone can help me go back to my original settings.
I just purchased a Samsung galaxy S4 Snap dragon quad core in Australia and just downloaded an app called Tiny flashlight +LED ( https://play.google.com/store/apps/details?id=com.devuni.flashlight) I then used the widget and it changed my notifaction bar to transparent.
Now when ever I use the app (widget) it turns on with a single click. And then when I go to turn it off I click the widget a black notifcation bar appears and quickly disappears then I have to click it again and it turns it off.
I was wondering if anyone knows how to reverse it (and I guess if someone wants a way to change there notification bar to transparent) I tried uninstalling the app but that didnt work.
Btw I have used this app and loved it on my S2. Also im sorry for the spelling. I really dont pike the new predictive suggesting completely wrong words so ive turned it off and I cant spell.
cheers for any insight that can be given.
Cheers
Cheers
Hi, welcome to the forums! It sounds like just a case of an app not playing nice with a new model phone. Leave feedback with the app developer and they will probably address it in a future update. BTW, my S3 has a built in flashlight widget. Does the S4 not have one?
Thanks for the response. I sent an e-mail to the developer but should probably leave some feedback on the app store site or something also? And yes the S4 has a built in widget for it (called assistive light) but its a 2x1 widget (im using it now) and this apps widget is a 1x1 icon. Im kinda getting used to the transparent theme though. And Cheers for the advice :)
