Nitrosolid
Okay im doing simple stuff and i dont know why im getting errors can you guys please help me out.I get errors on this line "add = (Button) findviewById(R.id.Btnadd);" and "counter".
Java code
Java code
PHP:
package com.example.counter;
import android.os.Bundle;
import android.app.Activity;
import android.view.Menu;
import android.widget.*;
public class Main extends Activity {
int counter;
Button add,sub;
TextView Display;
@Override
setContentView(R.layout.main);
counter = 0;
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
PHP:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<TextView
android:id="@+id/Tv1"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:textSize="45sp"
android:layout_gravity="center"
android:text="@string/TvDisplay"
android:textColor="#5DA2FC" />
<Button
android:id="@+id/Btnadd"
android:layout_width="250dp"
android:layout_gravity="center_horizontal"
android:text="@string/Btn1"
<Button
android:id="@+id/Btnsub"
android:text="@string/Btn2"
</LinearLayout>
