I messed up, Help!!!
I down loaded a battery saver to my MID Tablet and was playing around with it and turned my screen black,(the power way down). It boots up and I know its on I can hear it. I went to My Apps at Google play and uninstalled it hoping that would fix it but no. Every place I go tells me to open settings but if I could do that there would be no problem. HELP!!!!!!:mad::(
Welcome to the forums jptyler010!
I'm sorry you are having issues with your Tablet :(
Can you pull the battery out, wait about a minute, then power up? See if screen comes on ?
Not familiar with MID's but perhaps try it :)
Thanks for joining and if you have any more questions, just ask :)
Hi jptyler010, glad to have you here. :)
Please try what Mikestony above suggested, and let us know how it goes. If it doesn't work, we'll see if we can help you figure out a solution.
images
