Help I need a call recorder
racinmason001
There is some shyte going down right now and i need to record some calls for my own protection. Does anyone know of any recorders that don't have to be on speaker to record. Thanks in advance guys.
CallRecorder by skvalex is very good. It requires root to not need speaker, I know PGs plague kernels have support for it and I haven't had a problem with it on ldriftas speed kernel, but I don't know about blitz or homeless
Also, I feel I should tell you, be sure to check your states laws regarding recording phone calls. Most of them only require 1 party be aware of the tap but some (13 states, including Florida) requires everyone to consent to the recording
I use "Record my Call" by Nathaniel Kh. It works about 8 times outta 10, about 30 minutes of recording per call. Its pretty good.
the first kernel to support it was the blitz on mt broken out rom its the best and the elite way to record calls. important notice not that we care or whatever but just to be said some states its consider against the law to record a phone call without consent of the 2nd party. so just incase u decide to use a recorded phone call in a court in one of those states dont bother might cause more probs than anything else.
also now on google voice you can record incoming calls with pressing the number 4 on your dialpad but it gives an alert to both sides that call is being recorded lol.
https://play.google.com/store/apps/details?id=com.skvalex.callrecorder&hl=en
