Depending on your device, is that not an option that is already available on the incoming call screen? Either to "answer" or "decline with message"?i want 2 be able to answer either recieveing the call
or either by texting not able 2 recieve the call
and yes incoming call
let me ask u amother questionDepending on your device, is that not an option that is already available on the incoming call screen? Either to "answer" or "decline with message"?
Not sure but based on your reply, your call screen doesn't have that option already?let me ask u amother question
how can i make an if then flow
that ask me for yes (if i typs yes he will answer)
or no(sending an sms that i am not avaibale)
no i mean how to define the the text based triger in if then flowNot sure but based on your reply, your call screen doesn't have that option already?
tom how can make tasker ask me for the data the yes or no question ?Dev4
A1: Variable Set [ Name:%answer To:yes Recurse Variables:Off Do Maths:Off Append:Off ]
A2: Send SMS [ Number:6033577567 Message:happy birthday sis Store In Messaging App:Off ] If [ %answer ~ yes ]
Profile: ReadMessage
Event: Received Text [ Type:SMS Sender:* Content:* ]
Enter: Anon
A1: Say [ Text:Message from
%SMSRN
%SMSRB Engine:Voice:default:default Stream:3 Pitch:5 Speed:5 Respect Audio Focus:On Network:Off Continue Task Immediately:Off ]
Thom
Tom, in regards to your last statement..why does it keep answering back to my own number I'm am responding from?, can't seen to pass that issue..I've tried a thousand different ways
Dev (586)
A1: Popup Task Buttons [ Text: Mode:Text Task:A Task:B Task: Background Image: Layout:popup Task Buttons Timeout (Seconds):10 Show Over Keyguard:On ]
A (583)
A1: Flash [ Text:A Long:On ]
B (584)
A1: Flash [ Text:B Long:On ]
thanks tom u r great thx for the patienceWhen learning Tasker most people start with Tasks. After a few months they investigate Profiles. After a year they investigate Scenes.
Scenes can contain a wide variety of elements.
The way to ask a question and process the response is a to post a question in an element (like a Text or Button) and then process a response in a Tap or Long Tap action associated with that element.
Posting the code here from a scene is not really possible.
An alternative might be to use aPopup Task Buttons …
Dev (586)
A1: Popup Task Buttons [ Text: Mode:Text Task:A Task:B Task: Background Image: Layoutopup Task Buttons Timeout (Seconds):10 Show Over Keyguard:On ]
A (583)
B (584)
… Thom
