Help I need a few apps please help........
I'm loving my x10 but am peaved that I can't play dixv and avi files on it:mad: are there any decent FREE (important) media players that I can use?
Thanks very much
Have you tried importing the videos onto the phone via Sonys "Media go" its meant to convert video files into a readable format for the phone, failing that there are a few DivX players on the market but cant think of the names...
I believe rock divx player can play divx/xvid files on the X10. A link to the installer for it can be found in the "Your Top 5 Apps" thread. I would post it here but I don't want to take credit away from the person who posted it first. Also, you could try using Media Go to transfer your files to the phone. If it doesn't think the phone will be able to read the files (i.e. divx/xvid files), then Media Go will convert them and then transfer the converted file when the conversion is done. Hope this helps!
