I Need a word processor with print layout view.
falkner09
Member
So I have alot of .doc and .docx files I frequently view and edit for law school. problem is, they are all written in and meant for viewing in Word's print layout view, except for my class notes in Notebook layout view.
I've used docs to go and now Officesuite 5. both have the same problem: they can't do print layout view. instead, they format all text to fit the full screen width, so there's no text offscreen or white space at edges. this is a problem, because it totally screws up things like tables my professors put in their instructions, and anything with bullet points. worse, if I try to edit anything, I have no way of knowing what it's going to look like once I'm back on my computer, which is where I do about 95% of my work anyway. so I sometimes end up having to fix notes I try to take on my tablet or phone, and sometimes the edits I make end up with flaws I can't seem to fix.
Also, since my notes are done in the notebook view, I have different sections for my classes, and I use Word's tabs on the side of the display to quickly switch between the classes to find what I need. The mobile versions don't have this either, instead they require me to scroll through AAAAALLLL my notes from the first sections to get to the second, third, fourth, fifth. Not good, especially since each section can be over 50 pages.
TL,DR: I need an android word processor with a viewing option that matches MS Word's print layout view, and if it can also separate sections from Word's notebook view or let me jump between them easily, that would be great as well.
