Root I need help on how to revert to Stock Status Bar. Help!
HaTrEd360
Android Expert
Ughh, so I used Rom Toolbox Pro to install an Ics theme to my 3G icon on the status bar and I backed up the com.blahblahsomethingsystemui.apk to my internal storage, and now idk what to do on how to revert to stock status bar and get rid of the theme I made. I tried restoring my nandroid backup I made earlier after flashing CWM, and it works up until it tries to format the system and restore it, says it can't format /system. I'm stuck and have NO idea what to do. Can anyone explain to me on how to restore just the status bar to how it was??
Install the newest release of gp's cwm recovery. He fixed the system format option so that should fix it. He also just released an installer. Look at end of clockwork thread for links
