what about the
orbic wonder
we have some talented devs supporting the device here on this forum.
orbic wonder dev thread
check it out.
edit:ninja'd.....though i like my suggestion better
......lol
I wouldn't keep posting that Amazon link if you are promoting that phone.
The reviews are not good.
Reviews are not everything, I know, but some things sound worrysome.
First, the stats sound amazing. Too good for the cost, actually.
The description states that it has a 'scratch resistant' screen.
As a long time wearer of glasses, I take that to mean 'plastic with a scratch resistant coating'.
I also know that 'scratch resistant' basically means nothing.
I don't know for sure if the screen is plastic or glass, but I will say that I don't desire a plastic screen. That alone would be a deal breaker for me.
I clean all my phones the same way, and my glass screens are flawless, while the plastic one has scratches.
It appears that the battery life needs attention, and the fact that the phone is uncommon makes it difficult to get accessories for.
I am not knocking it, this is just what others have said.
I have had very good luck with my cheap ZTE phones,
The screen resolution of your mentioned device, along with the 16GB internal memory all sound great- and surpass my device.
But, if things such as the charger jack being proprietary and other issues I mentioned are true, then I would have to pass.
The phone sounds great on paper (or screen, as it is).
But I would want to inspect one in hand before I could endorse any product that I am not familiar with on a personal level.
