I need help.
Griflog
Recently talked Tmobile into sending me a Slide, and letting me keep the BHII. Used one of BH Man's roms to take the BHII back to stock to get it ready for resale. Now, i cannot load any apps onto the phone because it says "not enough memory". Checking the memory settings shows 0 Maximum, 0 available. I've done a factory reset, i've reflashed the rom twice, still no memory. Any ideas?
Your sure the rom flashed (ie the phone is actually running the stock/factory/etc)?
hmmm...have you tried removing/reinstalling ODIN? I'm just spitballing, but maybe your ODIN got corrupted and is write protecting the storage, or filling it with random junk in the flash. Hopefully somebody else would have a better idea.
Firmware version: 1.5
Baseband: t939uvja3
Kernal: 2.6.27
Re-downloaded Odin and all files, no luck.
dude i have no idea, i have never heard of that before, maybe use bh_man's recovery to delet all the memory, I think there was some different options in his recovery?!?!?!
