Help i need help ...
Hi,
I have a Hipstreet Phoenix (10DTB12) that is bootlooping. I still can get to the Stock Recovery, but ADB sideload dosent work (usb debbuging not enable...) . I downloaded a build of the stock firmware on a chineese website (baidu :/) , and i wonder if its possible to bypass the usb debbuging...
forgot to mention, the tablet detect sdcard has the /data folder...so sdcard doesnt work
PS: board name is EM_T8511A_V3.0L
ADB never works with a stock recovery in my experience. A custom recovery normally includes and ADB daemon, but not the stock one.
Can it flash your software from an sd card? If so use a card reader to copy the data to that, then put it back in the tablet.
Of course a bootloop may have many different causes. It might be worth clearing cache from recovery and seeing whether that's enough, or seeing whether it will boot in safe mode (in which case it's one of your apps that's the problem). Maybe even a factory reset, if you don't have important data on it. Just the fact that it's looping isn't enough to say what the cause is.
well, the thing is its dosent mount /storage/sdcard1 in recovery it go in /data instead ... and i can only boot in recovery mode , normal boot, or low battery charging mode... the stock recovery only has adb sideload, but i dont hve usb debugging enable... so...
How do I get my old gallery back
It doesn't sound like there's any connection between your problem and the original poster's one. So I suggest you start a new thread and describe in detail exactly what is wrong and how you got into that state. The more information you provide the better the chance that someone will be able to identify a solution.
