How are you trying to connect to a carrier? I mean, do you have a carrier, like AT&T or Sprint, but can't get your phone working with it? You can't just put a random SIM card in and then poke around in cyberspace trying to connect to a carrier.I have a Cubot max 2 and I can not get it to connect with a carrier.
Yes I have a carrier it's strait talk and yes I have a number. And I have to connect through att. And yes it's the right Sim. It's like it's not on the same band or frequency or something.
I'm pretty sure an imported China phone like the Cubot won't work, it can't be activated with that carrier in the US.
Yes I did and that's what made it start working the only problem now is it will only work on 2g. I am trying to figure out a apn. If it will take oneHave you try to insert a different carrier sim into this particular device?
