I need help
DAndre23
Hello I've had a captivate once before but I have gotton a new one,but the problem with this one is I have the 2 gb data plan and everyday for the past three months I have checked my data usage before I go to sleep and I would wake up the next morning and I would check it and would say I have used over 300 mb ,so if you have a solution to the problem I would really really appriciate it.. thank you
You can, but it would be better to get to the root of the problem first. You just need to check what app is using the most data, amend it's settings and/or uninstall.
Does the list you see look like this:
Underneath the GPRS/EDGE/3G 704MB, what is the next highest on the list, what does it say?
If you Settings -> Accounts & Sync, is Autosync set? If so, turn it off for now.
