Root I need help...!!!!!!!
so, long story short, I was running cyangenmod on rom 1.1 so I wanted to run jellybean so I started the rom upgrade to 1.2 following the instructions located @ [GUIDE] Fool proof install for stock 4349 (1.1 to 1.2 upgrade path) - SlateDroid.com
did everything to the letter however, somehow the old version or stock rom of the g tablet is now on my tablet. Its showing UI 1.0
I tried nvflash, I tried booting into clockwork to no avail. so now i'm on 1.0 and was trying to take the OTA update to 1.1, however the screen sticks on detect a recovery command, erasing MSC and booting recovery kernel image.
I have no idea what to do next. seems like i'm in a booting loop.
Any help or pointing in the right direction would be most helpful.
You've got to get CWM, on there again via NVFLASH, seriously start from scratch man. You also seem to know what you are doing, flashing wise, however do be patient too, let it finish what it needs too.
I've used the same method, I'm running 1.2, and DRH's Beta 1.3 and almost all works great, or better than it was.
Even when I got stuck, which sometimes happens, just start from scratch, I've yet to have my G-Tab be totally unusable. Yes, I've even had to reset the tablet, by opening it up and disconnecting the battery, LOL, apparently there's a reset switch I missed. (about centre of the tablet).
Please feel free to help this Dude, if you have a better idea than I! :)
