Root I need help
Xhektz
Hi i need help im Install CWM, but accidentally deleted all my MS323. Now I can not do anything. there a way to restore the STOCK ROM?
Are stuck in the LG logo, and does not advance from there. attempt to put him with the original rom LG FLASH TOOL but will not let me. sends me to CWM
I did the same thing lol..
I had to reinstall the LAF file so I could access oem recovery, then I used the LG tool to flash the KDZ.
I struggled to get the LG flash program to recognize my phone when it was just booting to CWM... plug the phone in to the computer and you should see a W5 in device manager, If you do the correct drivers are not installed, I used windows update to find them, once it installed correctly the LG flash tool allowed me to flash a KDZ... if you cant manage to revive it, send me the brick in the mail and I will try to fix for you.
