Root I need Help
Arlyn_1994
Hello :) I need a lot of help my lg tribute ls660 was bricked when I try to update to Zv6 and after I do a total format, System, data. I make a total format and after flash the stock recovery from Zv5 and now only appears the LG Logo.
I've tried many tutorial to install TWRP agian but I can't enter to Fastboot mode. I need my Phone back to life :( Help Me please :(
I'm really needed :(
oh if you cant boot into the recovery(stock, twrp or clockwork), boot loader(fastboot, download mode) and android at the same time your phone is bricked.
Sorry, Im really needed, i cant unbrick my phone. I've tried many treads but i can't I just can enter to download mode and Stock recovery help me please :(
Not being a wiseguy, but how can you boot into all of those at the same time?? Just that the OP is confused enough. :)
hash already un bricked a phone like yours also i never bricked mine in that way so i don't know how to un brick it.
Is it just me, or is the OP really confusing?
They obviously don't speak English natively, but they are trying to figure it out (android).
It might even be better for OP to edit the first post with the issue in their own language, maybe add it as a spoiler. At least that way we could run it through a translator and properly understand the issue.
Hola gracias amigo, perdon por mi ingles haha xD crees que podrias ayudarme??? No logro desbrickear mi telefono y necesito hacerlo
Me llego una actualizacion la descargue pero cuando instalo ya no arranco el sistema porque tenia el TWRP y entonces se brickeo intente flashear CM12 y no arranco entonces le flashee el recovery stock
Bueno se te brickeo por que la.actualizacion detecta que no tienes el recovery stock,el cm12 el mas reciente es el que funciona el otro distorsiona el boot.img y no arranca,cometiste un error al flashear recovery stock. Entonces solo se queda en el logo de lg? Y entra en el recovery normal?
Lo hice en un momento de desesperación, y si, entra a recovery, a Download Mode, y se queda en el Logo de LG
Si! Ya me maté buscandola y no la encuentro en ningun lugar, segun vi en una pagina, que ahi la tenian pero debia comprarla. Pensaba tratar de instalarle la stock del F60 pero no se que podria pasar xD
De hecho el cm12 que quisiste instalar es originalmente para el f60,yo instale el cm12 el reciente y no me funciono la camara ademas que vibraba cada 5 segundos,y tambien se me brickeo y tambien busque el kdz pero yo nunca cambie de recovery
