Root i need kernal help
Bman123
I need help finding a kernal to use on my bolt. I did the leaked gb update and I want a kernal that will let me overclock underclock and undervolt. Can some be kind enough to link me to a kernal
Unless you are rooted you are unable to change kernels. I assume since you did the leaked update you are not rooted. If that is the case then check out revolutionary to get root access
Most of them are for aosp tons I'm running sense so ut looks like the only one that will work is leankernal right
Dreamkernel has Sense builds. I think team BAMF may have flashable sense kernels listed on their website
