Do this:
Step 1.) Open Odin.exe and plug a usb cable to your computer that will connect to your phone (do not plug it in to the phone yet, just the computer)
Step 2.) Hold down both volume buttons at the same time and while holding them down plug the usb into your phone. You should see a COM message show up in Odin.
Step 3.) Leave all check boxes the way they are. Do NOT check the repartition box.
Step 4.) Click the PIT button and select the 512.pit file
Step 5.) Click the PDA button and select T959UVJFD.tar and then click Start
you should be done with all this in 15-20 minutes.
