WARNING!!! THIS WILL WIPE ANY DATA ON YOUR DEVICE, IT WILL REPLACE YOUR BASEBAND, KERNEL, RECOVERY AND OS. DOWNLOADS:
INSTRUCTIONS:
1.Your Device must be in DOWNLOAD mode to use ODIN.
2.Get your phone into DOWNLOAD mode by turning off your phone and plugging it in. Wait for the green charging screen. Hold Volume Up, Volume down, and Power. Let go of power as soon as the screen goes black. A yellow digging Android should be on the screen. This may take a few tries to get it right. (Alternate Method if you have ADB access : use the command ‘adb reboot download’
3. Launch ODIN, then disconnect/reconnect your phone via USB. It should then say a COM port right under top-right box. (Issues detecting your device on a COM port? Try connecting your phone before starting ODIN, and don’t do the disconnect\reconnect. It’s a finicky application.)
4.In ODIN, load each file with its corresponding field..PIT,PDA,CSC etc. (In this case we just use the PDA and PIT).
5.Don’t check anything else, the other two boxes should be checked by default (Auto Reboot and Reset Time)
6.Hit “start.”
Be patient!
NOTE: COM3 worked fine for me. COM should not matter as long as you are using the correct drivers.
