Hello. I own a very cute SGM.
Today I found out about Gingerbread firmware, so I decided to upgrade via Kies.
I opened Kies, updated and then connected my smartphone to PC.
Update started...
After a few minutes.
Update failed...
I used the emergency recovery.
Well, I put that window in the right side of the screen.
Now I found out that Kies is frozen...
In Task Manager, it says it is running...
Can't do nothing with Kies now. Frozen forever.
How to help my phone?
P.s: If it helps, I use Windows XP SP 3, 2GB of RAM...
Thank you
Update started...
Update failed...
Thank you
