Help I screwed up. help please
Iamtoast
Ok. Long store. Threw phone at floor and regret it now. Phone screen is broken but it works but phone shuts off when calling either on facebook or on the phone itself. This is the log it gave me. Ideas?
--------- beginning of system
I/Activity( 5838): Activity.onPostResume() called
I/Timeline( 5838): Timeline: Activity_idle id: android.os.BinderProxy@14aa03b1 time:66719
I/ViewRootImpl( 5838): ViewRoot's Touch Event : ACTION_DOWN
I/ViewRootImpl( 5838): ViewRoot's Touch Event : ACTION_UP
W/ViewRootImpl( 5838): Dropping event due to root view being removed: MotionEvent { action=ACTION_MOVE, id[0]=0, x[0]=315.15118, y[0]=645.3942, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=86904, downTime=86888, deviceId=5, source=0x1002 }
--------- beginning of main
W/TouchFlickNoti( 5838): CAPP_TOUCH_FLICK: DOWN vectorVelocity:60 signal:1
I/ViewRootImpl( 5838): CPU Rendering VSync enable = true
I/Timeline( 5838): Timeline: Activity_idle id: android.os.BinderProxy@14aa03b1 time:140273
Hi and welcome to Android Forums! Yep, phones and gravity are a bad mix. The SIM slot or circuits may have been damaged, the CPU might be damaged... any number of things could have gone wrong on impact. You can try reseating the SIM card; if that fails, you're up to a decision between two expensive options: have the phone repaired at the manufacturer or replace it.
