Wondering if any of you guys could help me out here?
By the way, if this is the wrong section for this, apologies and feel free to move?
Nexus 7, 16gb, rooted with stock 4.1.2. I have not edited the build.prop, still using the 4.1.2 Keyboard, Gmail etc.
So, nothing changed other than unlocked/rooted.
I have superSU pro and have 'Survival Mode' enabled, which is basically and OTA Rootkeeper (I am sure you already know this...)
When we got the OTA to 4.1.2, it worked no problem, survival mode worked and I kept root and custom recovery.
So this morning I get a notification to upgrade to 4.2, which I done. It restarted, and installed with no errors etc, then comes the Google screen with the unlocked padlock... and it stayed this way for an hour, so I am assuming it is borked?
I restarted it, same again, so rebooted into the bootlaoder menu. Going into recovery shows the android dude on his back, red triangle ! etc, so I gather my custom recovery is gone.
So the question is, where to go from here, and is there a walkthrough I can use to resuce this (I am techy enough minded, but given the state it is in, loathed to make it worse down to sheer stupidity)?
Any help would be much appreciated guys.
BTW - I used Wugs Toolkit to root, so that is all set up with drivers etc, can that be used now to recover?
