Help I want to keep my LG motion, but...
I recently moved to Idaho, and took my LG motion 4G with me. Upon arrival I found out there are no Metro PCS stores here, and my phone does not get service. I was wondering if anyone knew if it was possible to remove the SIM card and put a new one in it, to get a new carrier, or if I'll just have to buy a whole new phone? If I do have to buy a new phone, is there a way to transfer absolutely all of my data/documents onto the new one so I don't lose anything?
The Motion uses CDMA for voice calling. The UICC card (it's not a true SIM card) is only for LTE.
There are no other carriers in the United States that use CDMA, besides Verizon, and they aren't going to let you activate a Motion on their network.
Sprint is CDMA also, but I don't believe that they'll let you take a non-Sprint phone to their network either.
To answer your question, yes, you'll probably have to get a new phone. Check what carriers are in you area and find out which one has the best options for you.
T-Mobile shows LTE coverage in Pocatello, Boise, Idaho Falls, and Couer D'Lane.
When I had a Motion, I was able to pick up T Mobile LTE in places where Metro PCS had no service, like Albuquerque, New Mexico and Fresno, CA. So at a minimum, you should be able to get LTE in those places.
First, what the others said.
If you have you phone backed up with a Google account most all your data and documents should be in the cloud. And even without MPC service, you should be able to get that stuff up to Google with a wifi connection.
you could also use a usb cable.
