Root i500 showcase recovery problem
maximus57
I have a Samsung Galaxy S Showcase i500 from a local carrier (most likely a version of the Verizon phone). The rom version showed E120. I finally decided to root it, and found the only way to do it was to install the clockworkmod with Odin, which went successfully. The very next thing I did was made a backup with clockworkmod recovery to the SD card (I also copied everything from the SD card to my computer after different steps for everything I did and will do). I installed superuser and mybackup root and also made a backup with that. Everything was going ok.
Then I decided since I had my rom backed up with clockwork, I felt safe to try cyanogenmod7.1 (the one I used was for Cellular South, only one available for my phone). I followed the instructions and had a successful flash, but 3G didn
