This worked for me
[FONT="]Then try with Google Maps.[/FONT]
- [FONT="]Press *#*#1472365#*#*. This will bring to GPS setting.[/FONT]
- [FONT="]Settings [/FONT][FONT="]-> Parameter Settings -> Address -> Server Type: 1x MPC [/FONT]
- [FONT="]Settings [/FONT][FONT="]-> Parameter Settings -> Position mode: option3[/FONT]
- [FONT="]Settings [/FONT][FONT="]-> Fix Request Settings -> Session Operation: Standalone[/FONT]
- [FONT="]Settings [/FONT][FONT="]-> Fix Request Settings -> Server Option: Local[/FONT]
- [FONT="]gpsOne XTRA[/FONT][FONT="] -> Xtra Enable: Enable[/FONT]
[FONT="]If you want to go back to the default setting:[/FONT]
- [FONT="]Settings -> Parameter Settings -> Address -> Server Type: UMTS SLP[/FONT]
- [FONT="]Settings -> Parameter Settings -> Position mode: option2[/FONT]
- [FONT="]Settings -> Fix Request Settings -> Session Operation: MS-based[/FONT]
- [FONT="]Settings -> Fix Request Settings -> Server Option: Default[/FONT]
This didn't work for me but I did find this code *#*#1575#*#* which brings up a GPS menu with options, but I havent got a clue what to do from there!
If you're on Froyo try these commands:
use Froyo code : *#*#3214789650#*#*
after restart go to : Commands->Get Position ->Start GPS (it might be long test)
i did this only and now i get locks within 10-20 secs
for better results USE GPS under open skys
Thanks Barqers, but tried this and got error message: "The application service mode (process.com.sec.android.app.servocemodeapp) has stopped unexpectedly".
Search for a solution goes on...
That might be the problem lol, isn't that the process which handles GPS data? If it's force closing it might be a problem with the apk itself. Are you using a custom ROM?That might be the problem lol, isn't that the process which handles GPS data? If it's force closing it might be a problem with the apk itself. Are you using a custom ROM?
