Ibolt and extended battery?
golfinglenn
I have done a lot of searching but haven't found this answer yet:
Does anyone use the Ibolt with an extended battery? I have the Hyperion extended battery with silicone case from amazon and wondering if they will fit in the Ibolt?
Thanks,
Glenn
If it doesn't work with a thick case like an otterbox then I wouldn't think it would work with the extended battery.
Thanks,
Glenn
Yup, I have both and works out well. The sound comes through my Subaru's Audio system really good too!
