nuttmeg
Extreme Android User
This is only for metropcs users running Icarus 1.1, as the APN settings are wrong.
Here's the fix:
1. Go to Settings > Wireless and networks >Mobile networks > Access Point Names
2. Press menu and select new APN.
3. Enter the following info.
APN: <Not set>
Proxy: proxy.metropcs.net
Port: 3128
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMSC: http://mms.metropcs.net:3128/mmsc
MMS proxy: <Not set>
MMS port: <Not set>
MCC: 310
MNC; 16
Authentication type: PAP or CHAP
APN type: default,supl,mms
4. After you have entered the above, press menu and save. Now make sure that the new apn has a green dot beside it.
5. Now you should be able to send and receive mms messages
Here's the fix:
APN: <Not set>
Port: 3128
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMS port: <Not set>
MCC: 310
MNC; 16
thanks for this thread and icarus
