Icon Bluetooth = Bluetooth Enabled
emiegna
Hi,
A few days ago*I've*started in*Tasker*and want to create*a task,*but I am not*able to.*No*if you could help me, please.*
I have in*the startup*of*my*smartphone*several widget*created with*Minimalistic*Text.*The*widget*at the top*left is*a single widget*with five*lines (row).*By clicking on*this widget*bluetooth*enabled,*and*click*again on the bluetooth*widget*is disabled.*I want*that when the bluetooth*is activated*bluetooth*icon*appears*and when*I turn the*bluetooth*bluetooth*icon disappears.*Can I*you can*help, please?
I don't think there's any Tasker native function or 3rd party plugin function to make an icon invisible (or even grayed out).
Thank you very much for responding. But perhaps it would be possible that the icon would change color depending on whether Bluetooth is on or off, no?
I'm pretty sure Rukbat is correct; Tasker doesn't have any way to control the system status icons.
Finally this is what I created. I added a text widget, "blu", and to activate the bluetooth "blu on", and disable bluetooth "blu off".
Perfil: Bluetooth Ntf (37)
Estado: Estado BT [ Estado:Si ]
Entrada: Bt On Ntf (38)
A1: Minimalistic Text [ Configuraci
