Apps Icon wider than 24p on status bar?
UXWarrior
1
0
Hi, can an Android app produce an icon wider than 24p on the status bar?
Or can it show some text on the status bar?
I would love to show in the status bar either:
  • An icon wider than 24p (so that I can fit in text like "1h29m left!")
  • Text, e.g. "You have 1h29m left!"
It'll be a deadlining app. There is an ongoing notification that refreshes the remaining time every minute - it would be great if the remaining time could be displayed straight away on the status bar so that the user can view it at all times - without the need to swipe down to see the notification bar every time. 24p is too narrow.
Thanks a lot!
BEST TECH IN 2023
Smartphones
