sujisurjith
Hello tech savvy's... I need help instantly... Is there any way to install samsung tab3 firmware in acer iconia tab??
Ok...... The real thing i want to say is.... My tab... That is acer iconia b1 711 is stuck with an error..... Its showing up"process.phone.... has stopped"... I did a hard reset.. Wiped data everything but in vain.... And there is no firmware available for my tab anywhere in internet.... Plz.. Help me.... I want to use this tab...Hello tech savvy's... I need help instantly... Is there any way to install samsung tab3 firmware in acer iconia tab??
hey.. Presidente... When i download its shows 452mb but it finishes that second itself... Only 2.5KB!!!It's an acer iconia b1 711 yeah?
There claims to be original firmware here: http://forum.gsmhosting.com/vbb/f83...er-flashfiles-1674042/index2.html#post9840441
I can't confirm it's legit and I've no idea how to flash it, so proceed at your own risk...
i dont have backup.. My tab is iconia b1 711... And im having normal recovery.... Not any custom..A factory reset only deletes user-installed apps and data. It won't change anything in the system, so if you changed the system software a factory reset won't fix that.
If you made a backup before messing with the system restoring that will fix it (and if not, next time you know why you should).
If you are using a custom recovery then you should be able to toggle off verification in the recovery settings without modifying the zip. But before doing anything else, do you know what is in that "update.zip"? Because it could be anything, and if you don't know there is no guarantee it won't make things worse.
Otherwise, exactly which model is the "Acer iconica tab"? If it's the A100 then you can find a few ROMs here. If it's a different model let us know and we'll see what we can find - do not try to flash a ROM intended for a different device. And make a backup using your custom recovery before you try to flash the ROM, so that if anything goes wrong you can at least get back to where you are now.
Its an html file bro.....hey.. Presidente... When i download its shows 452mb but it finishes that second itself... Only 2.5KB!!!
It's not. If you click the link as opposed to saving it, you are taken to a download page which gives you a password. That page then redirects to the actual download which in turn asks for the password to confirm the download.
The file is 460MB, click on the link, go to the d/l page and enter the password. I d/l no problem
Yep, same here.
Under settings, please make sure that cloud boost is off.Im using android phone BROWSER... UC BROWSER
Ok ok everybody do one thing.. U start downloading the file let it hit upto 5mb... If it hits then inform me... Guyzzzz... Cool bros...Under settings, please make sure that cloud boost is off.
Three of us have already downloaded the whole 450 MB file.Ok ok everybody do one thing.. U start downloading the file let it hit upto 5mb... If it hits then inform me... Guyzzzz... Cool bros...
