Help [ICONS] Droid Plain Text
rendeiro2005
Based on Droid fonts made some icons containing the following:
alarm, astro file manager, facebook, sony backup & restore, busybox, calculator, calendar, camera, contacts, email, gtalk, maps, market, mediascape, navigator, oi file manager, phone, root explorer, scanner, sms, timescape, titanium backup, tools, web browser, xda app.
Currently I use the ADW as home replacement, so the icons are placed here with the size and settings for ADW, however, it is likely that they work perfectly on other home replacements.
I use Desktop Visualizer to change my icons. You can find it for free on Market but i`m sure you can use another program to do this.
10-21-2010 create first pack of SimpleDroidIcons for Xperia X10
10-22-2010 extended version for SimpleDroidIcons for Xperia X10
SIMPLE DROID ICONS
BLACK GREEN
ORANGE
RED
WHITE
x10BLUE
EXTENDED VERSION
BLACK GREEN
ORANGE RED
WHITE x10BLUE
Good stuff, keep it up! maybe add a smaller text underneath? Use small pixel sized font and i believe that would look killa!
Either way thanks for sharing your hard work and time.:)
Does each "icon" need to be 4 letters then?
Seems odd that web is "webb" an
d phone is "phne"
Hi,
It doenst had to have 4 letters but i had to figure a way to do it all the same way. If i put 5 or 6 some commands will be to bigger. Just that.
About the example you give "WEBB" as you can see on file name is WebBrowser.
By the way. Sorry for my englh.
Maybe youre wright but what i what to do is mostsimple as possible.
But maybe ill do that.
And thks for your words
do you mean something like this?
Hi,
Ah it all makes sense now "WebBrowser" :o
Oh and your spelling is better than mine and I am english :D
anyway, and returning to prefer this WEBB way because it would maintain the words with four letters without looking stupid.
I will try and follow the oard of Phlash to make it more clear to those who use for the first time (although it is a matter of habituation).
