Help Icons keep on reseting.
JasonRaff
Everytime I reset my phone or turn it off , the icons on my htc sensations homescreen just reset to a android one. Its really annoying. (The icons are from apps moved to the sd card)
It's a known bug (or "feature"!) .. If you download a free app called "Fast Reboot" from the Android Market and run that when it happens, they will all be reinstated. It's something to do I believe with the cached images not refreshing quickly enough so they fall to the default icons (something like that anyway). Bound to be fixed in a future update, but use that utility and it'll solve it. Happens to me quite often.
Easy fix, don't move apps to the SD card as you don't need to. We have 1GB of space so you'd need to have a LOT of apps to use that up
This problem is fixed with the new android update (2.3.4) , I think so.
I Concur, the 2.3.4 update seems to have fixed this for me. Eddy makes a fair point though, you dont really need to move installed apps to sd card with 1gb of internal memory for them.
I dont get why so many people keep complaining either, about the sensation only having 1gb of internal storage. You'd have to install a hell of a lot of apps to use all that up.
Cheers
works a treat, cheers mate, as reguards those thoughtful people that tell us its not needed, true it myt not be necassary but the reason i own android is because of its wonderful policy "because i can" also i am updating the wofully inadicate desire i own to gingerbread and i will need to app2sd than :)
