Hello everybody!
I just got my first android device, an Ainol Novo 7 Advanced II Tablet, it has Android 4.0.3 ICS, and its working great.
The thing is, i want to encrypt the tablet (in case it gets stolen or something, you know).
So, following instructions i found somewhere, i did this...
1.- I pluged in the AC charger (so i wouldnt run out of battery midway)
2.- I went to settings->security->Screen Lock and selected Password, this worked fine, now i have to type my password to unlock the screen.
3.- Went to Settings->security->Encrypt tablet, I was warned that this process would take over an hour, that the process should not be interrupted, etc, etc.
4.- I typed in my password when prompted and hit encrypt tablet.
The screen went black, with a green android robot in the center. I jus let it sit there for about 5 (yes FIVE) hours!, but nothing ever happened, whenever i looked at the screen the green robot was just sitting there. no progress bar, no errors, no "im done" notices, no reboot, notnhing.
After five hours, i just pressed the home button, and the normal desktop came in!.
I rebooted the tablet, and i only got asked for my password at the lock screen as before, went to settings again, and the option to encrypt the tablet is still there.
In other words, it dint encrypt anything! but still i got no errors, warnings, of any kind.
Did i miss something? is there something wrong with my tablet?
any input greatly appreciated.
