ICS Exchange Connection Error
mylesp
Hi
I have just upgraded to ICS (v4.0.3) on Samsung Galaxy S2 and my Exchange Account is now getting a connection error. The settings are all the same that was working fine prior to the OS upgrade. It is set to use SSL and Accept All SSL Certificates. I have tried with "Use client certificate" on and off. It seems to connect fine as I get a message "Server must be able to remotely control some security features on your device. Continue?" If I select OK it doesn't come up with any further information, however when I go to email it comes up with a message "Connection error" with no further details.
I have tried entering the incorrect username and it detects that it is incorrect.
Many thanks
Myles
