ICS home screen question
Just picked up my new phone (Xperia J) which runs ICS 4.0.4. I like to have a nice clean home screen so I have stripped out all the timescape stuff and weather widgets etc and got everything i want on one screen.
But my question is, can I get rid of the other 4 possible screens to the side of my current one?
Cheers
Maccattack
You will most likely need a different launcher.
I use Nova Prime and it is awesome.
You can also look at Apex.
I agree with Rocco. I'm not familiar with your device, but a different launcher gives you alot more options as far as home screens etc. He listed a couple too...Also
another is GoLauncher available in the Play Store. That is one of many different launchers available:)
Doing what Mike said will definitely yield the best results in trying to delete your excess screens. As i believe with stock launchers you might not even be able to delete or add more.
