ICS is out! Improves product immensely.
Le Pan II Upgrade to Ice Cream Sandwich 4.0.4. , Le Pan
Many of us over at the Let Pan Life Forums are running it. You'll find very helpful folks if you run into issues. No traffic for our tablets over here unfortunately.
I am sorry there is no traffic over here as I am trying to get into the fastboot mode by hitting vol+ and power together and holding until I see in upper left... YET I cannot get anything but regular boot.
How long does this process take as it has been in fastboot mode for more than 15 minutes now and the blasted cmd prompt went by so fast I have ZERO idea what in the world is happening, but I think I now have a brick.
Actually my brick I restarted with a pin in the back so I was then able to restart the process and it is now successfully updated to ICS.
I just updated to ICS per the LePan PDF and had a few problems so I thought that I would share these and how I stumbled on the fixes.
First, I could not get the tablet into "fastboot" mode. I tried the Vol + and Power buttons together many times and all I would get is a normal boot. Then I read many of the forums and one said something about the "hold" switch. Sure enough having the switch in off mode (switch to the left) cured one of the problems. Then I could get in "recovery" mode with Vol - and power but not "fastboot". So I did a reset with the pinhole and that finally fixed everything. The ICS update went exactly as the PDF instructions state.
Hi guys, I want to try to update my new le pan 2 to ics on windows 7 and the first part of the instructions say to use the rar file. I don't have winrar and don't want to dish out for it. There is a link at the end of the rar link on the le pan website where the upgrade is that says "zip file". I know I can unzip something. So should/can I use the zip file instead? Thanks for any help.:confused:
