ICS OTA issue
Qualme
Hello,
I have a Bell HTC raider, Im trying to update my phone with the ICS OTA update that was released yesterday however every time I run the update it stops with a red triangle.
I have unlocked the bootloader and rooted so I assume that is my problem. I tried relocking the bootloader but that did not help. Is there anyway I can install the Bell update manually?
Thanks,
Dan
Usually to do an over the air update you need to be completely stock. So, unroot and make sure everything is stock (including your recovery) before trying again. Also if you go over to xda forums, and look for the forum for your particular phone, a dev may have packed up a version of the latest over the air, for root users to install.
Thanks for the help, I just ended up backing up everything and reflashing my phone with the stock RUU then installing the OTA and restoring my data.
