Root ICS roms out there
Wonder if someone can help me with this. I rooted yesterday and flashed [ROM] [KANG] CyanogenMod 9 For the Galaxy Tab 10.1 Wi-Fi (1/26/2012). Everything works great except the computer doesn't recognize the tab when I connect via the usb cable. I reinstalled the drivers but it didnt work. Anybody have any ideas. Thanks in advance.
Sure can.
Go into settings -> storage -> click the 3 dots on the upper right
Select the only option (USB computer connection) and pick Media Device.
This will get you access to the internal storage on your computer.
Sure can.
Spent hours on this and knew it was something I was just overlooking.
Thanks Again.
is there a quick fix for the camera such as copying a working bit of camera code in it's place from either the factory or another file? just curiosity
not yet. im sure someone will get this fixed this year. i wish sammy would just release the code, thats about the only thing that makes me mad with them.
I really want ICS or even better jelly.... But I use my camera quit often. =(
Official Stock ICS ROMs for the UK/Europe region were dropped yesterday and today, depending on which variant you have you can probably install s stock UK one for your model, and your cam should still work.
I can confirm that the EU version works well, and the camera works as expected, as do all the other features. This is with the stock Samsung firmware update for ICS v4.0.4 on a Canadian Edition P7500. It removed all the Rogers carrier crap and gave me a nice clean setup...no issues at all and it's a very nice improvement over Honeycomb.
I'm a happy camper.
:D
I tested CM10 JB and it was good, but some apps crashed several times and no camera. I now have the official Samsung ICS version 4.0.4 running on my Tab and it's very nicely done. I can see why it took so long to port TouchWiz with a clean and efficient visual experience.
with TouchWiz ICS running well on my Tab 10.1, what would I get from switching to another ICS ROM? (getting rid of TouchWiz of course, but other than that...)
thanks.
