ICS to run on PC
lrollo
I have a Dell Inspiron 6400 with Intel dual core CPU on which I want to run a version of Android, preferably 4.0.x for demonstrations to a group of senior citizens.
I did a Goggle search and tried several suggested methods, but most of them seem to be tied to specific branded hardware. These included VM and VMPlayer, but without success.
I find virtually all the video demonstration so poor quality as not to be helpful.
I have SKD already install as a prerequisite to running Droid@Screen (which runs well).
Does anyone know of a generic-based set up I can try. or any other solutions that are known work.
I prefer text based instructions supported with screen captures of the ACTUAL PROGRAMS and ISOs used that can be run on my Samsung Tablet as PDFs.
While you can run Android ICS(Android-x86) on a PC, either virtually or on the bare metal, as they say. While I did get it to work, but I have to say it is alpha, networking doesn't work for a start, so no internet.
They only do it pre-built for specific popular brands, like Asus and Lenovo, and presumably PCs that the devs are using, because each build has to be unique for certain hardware.
Download - Android-x86 - Porting Android to x86
Emulators that have previously mentioned have the overhead involved with Windows and binary translation.
Android X86 will run natively on most modern systems.
A good number of apps are said to work just fine with android x86.
MHL hooked up to a real android device would be better.
