First post... and I have searched through the forums for somewhat of an answer to my issue but haven't come across one. Also, I cannot register over at the Eclipse ROM forum... where this question admittedly should be, though maybe it relates to general ICS update issues as well.
I was previously running Playfulgod's Black Plague, and decided to take the ICS update so I could install Nitro's Alpha ver. 3 build of Eclipse ICS. Once I took the ICS update (wiped everything prior to updating), I rooted (using AllinOnePackageSpectrum.zip), then did Bootloader Pwnage Tool for unlocked bootloader, then installed ROM Manager and flashed the cwm_bootloop_fix. Phone was worked okay, until the installation of Eclipse A3, this happens:
The phone reboots into recovery and begins installation. I get the "Installation complete!" line and then.... nothing. It stays in recovery and doesn't do anything. So, I took the battery out and rebooted into a brick. Thankfully, using Neph81's guide to unbricking, I flashed the V7.cab and am now on ICS stock.
What are your thoughts on this? BTW, I tried this twice, with the same result.
