ID in use
Hello there!
Are you trying to assign a specific ringtone to a certain contact?
Not sure I've seen that before, but that doesn't anything;)
Walk me through the steps you are taking leading up to that message and we'll see what we can help with :)
Hello there!
...hi thank you for your response but I figured out my problem it was in settings then went to sound and ID ringtones was turned on so I turned it off all is good here thank you again you were the one n only response appreciate it
Oh, no problem and glad you found the solution!
Thanks for posting it as others may benefit from it too:)
Cheers!
Cheers!
Peace out brother love!
