Help identify notification symbol
Deanjune
Hi, does anyone know what app the notification symbol is associated with? Looks like an antenna with two rings around it...I have included a photo
Hi. Can anyone tell me what app this symbol is associated with? I've included a picture. Looks like an antenna with two rings above it
If you pull down the notification bar, it should tell what it's about, along with the BBM notification, and what looks like a voicemail notification
Here;s a tip from the Note 4 usres manual that might help you out;
My Galaxy Note 4 shows some notification icons that are not shown here, what do they mean?
If the notification is on the left side of the status bar, it is usually from third-party apps.
Very often, there is also a notification in the notification area when such notification icons are displayed.
Tap and hold the notification until App info pops out. You can tap the app info to find out the app that shows the notification icon.
Those icons look like they're on the left side to me. Give it a try and tell us what you find Deanjune. Welcome to Android Forums BTW.
