Root Ideos rom with working data but no calls
icsideos is based off of cm7.2 which works for m835 . so if you want that look you can just flash cm7.2 to m835 and download ics theme then extract the apks from the rom that you like and move to system/app simple as that
It won't work like that Swis because there is no LDPI ICS mod on the Market so i thank MrGlowy for this.
Yes there is LDPI Ics CM7 Themes : https://play.google.com/store/apps/...wyLDEsImNvbS5hY2hlcC50aGVtZS5JQ1NhbmR3aWNoIl0.
This One Says HDPI only but works for LDPI only prob. is no google search icon : https://play.google.com/store/apps/...1bGwsMSwxLDEwOSwiY29tLnNvbm55LnRoZW1lLmljcyJd
As for Extracting Apks Idk if it would work but 9|10 it would because they are based off same os , unless its built into framework . and cm7 themechooser themes basically all system apps , and downloaded ...
I found another ideos rom . Everything works but I can't get mms to work. I've flashed metroff but it still doesn't work. Can you guys help. I'll post the link to the rom later.
post link and sorry i gave up on the update for the htc rom . i am tired of froyo , the whole os is highly outdated . so i guess we have to search more roms with higher os . the best i gotv( is 2.3.7 on cm7 .searching for ics at the moment but anything is possible with android ;)
this is the exact same rom i told you to try when you first commented about screen sensitivity . lol .. and i never noticed this prob.. because i dont use my huawei for calls :p well wait for the update the dev is coming back after 2nd week of August
maybe its something in build.prop idk ? read it look for mms and change it to the way huawei originally looks see if it works
also you can fix the rotation broblem by pushing the stock camera from mate35 into system dont overwrite your camera . it will fc .. also if you turn the screen upside down it will break again . so go in cm7 setting and uncheck 270 degrees rotate
2 Ways To Set Apns Manually:
Go into VoiceDialer Say Apn or Open Apn .
Click Dialog Box after opened
click menu softkey
click add
Fill in with the following:
APN: #777
proxy: proxy.metropcs.net
port: 3128
username: yourphonenumber@aaaj.mymetropcs.com (Ex.7862224444@aa
password: mymetro
mmsc: http://mms.metropcs.net:3128/mmsc
mcc: 311
mnc: 660
type: PAP or CHAP
apn type : *
click menu softkey
click save
APN Setting Will Not Show Maybe A Bug Maybe ?? But they are Applied.
Easy Way (While On Stock With Working Data,Calls,MMS,etc.)
Download
https://play.google.com/store/apps/details?id=com.riteshsahu.APNBackupRestore&feature=search_result
Backup APN
Move app to sd with root browser from /data/app to /sdcard for easy acess
Flash CyanogenMod 7, G-Apps,MMSFIX.zip.
Use stock file browser to install APNBackupRestore .
Restore Backup .
Reboot ( Optional but recommended )
I have confirmed this to work using TextPlus.
Before Flashing MMSFix Couldnt Text
After Text Message Was Sent Succesfully.
I tried both ways but it doesn't seem to fix it. I'll stick to stock for now. Thanks for the help though
Wierd try re-flshing and then do the process over . i have tweaked mine multipile times and forgot what i did . that could be the problem . also at first i was just experimenting and flashed
also try setting apns first make sure you save then flash then seting apns again . ALSO THE PASSWORD I USED WAS "mymetro" i got the other one from nu2modding post on the xda forums ... maybe thats the prob. that password was for a gingerbread phone ...
ALSO Try PGs One too . i tried the other one cause someone on LG Optimus had problems ... Also im might extract my /system and create it into a rom for m835 if you like maybe it would work that way
would you please? I have flashed PGs . it didn't work either
okay . ill see what i can do.. also to save me about 1 hour of my time .. can you download a MMS app from market (prefferably Textplus so i can see whats the problem)
found my phone :P
When You SAY MMS you MULTI-Media AS in Picture MMS ? because i was focusing on sms
