Apps If statement Problem
mizzeeboy
Ok so im trying to make a app that opens a toast saying you are incorrect or correct although im having some trouble with my if statements can someone please tell me what the problem is
Code:
public class IfActivity extends Activity {
	Button GO;
	EditText TEXT;
	/** Called when the activity is first created. */
	@Override
	public void onCreate(Bundle savedInstanceState) {
		setContentView(R.layout.main);
		GO = (Button) findViewById(R.id.go);
		TEXT = (EditText) findViewById(R.id.Textin);
		GO.setOnClickListener(new View.OnClickListener() {
			public void onClick(View arg0) {
				// TODO Auto-generated method stub
				if ("hello".equals(TEXT)) {
					Toast andEggs = Toast.makeText(IfActivity.this,
							"PASSWORD IS CORRECT", Toast.LENGTH_SHORT);
					andEggs.show();
				} else {
							"PASSWORD IS INCORRECT", Toast.LENGTH_SHORT);
					andEggs.show();
Your if's are built up correctly, but your comparison is incorrect. You are trying to compare the text "hello" with the EditText control TEXT. Instead you must compare the text "hello" with the text inside the EditText like this:
Code:
if ("hello".equals(TEXT.getText().toString())
