Help If you do a master reset/factory reset...
nhw
If you do a master reset with the Nexus one will you lose all your apps? even the ones that you purchased?
if you do a master reset, your Nexus One will be without any purchased/downloaded apps, but fortunately, if you "login" with the same Google Account, which is the only way it makes sense (if you are keeping it), you will recover all the apps
  • Like
Reactions: nhw
or you can back up your apps to your microSD with apps2sd another forum member on another thread suggested mybackup pro.
No one has mentioned THE most valuable app you can have. If you loose all your apps for any reason, what a pain to download them all over. Possibly, how costly? I have mybackup pro and have used it several times. I had to exchange a faulty Droid twice and I can't imagine dwnlding all my apps again. Plus, the program also saves and can restore data. Mybackup is the only one I have found that backs everything and I have looked
  • Like
Reactions: nhw
