iGO clear data consequences
vinci
I was wondering, how does clearing data for the iGO application on android affect the application itself? Am I running the risk of having to reinstall it?
Thanks in advance
Any time you clear the data for an app it resets the app back to its default settings (login, passwords, personal settings and whatnot are reset).
Clearing the cache doesn't do that (it clears temporary files that the app uses while its running).
Well, yeah, I guess I knew that, but the reason why I was asking about iGO in particular was that the cache&co occupies more than 30MB, which is a lot for htc explorer (it has a very small internal memory), so I wasn't really sure what could iGO store there except some menu settings
