Help I'm desperate to get flash player for my a70
Idk5
is it possible? flash lite or lower version of adobe flash or anything similar? or is it possible after rooting and increasing CPU speed? this is not fair this device should support flash lite atleast. oh I'm really sad :(
I donot think flash is supported. some flash apk's installs fine but you wont be able to view any flash content and some donot install at all
It does work but fcs on flash heavy sites..
Our SoC is Armv6 and the minimum requirement for official flash player is Armv7.. Thats why we cant use Flash :/..
No, overclocking wont make flash work as armv7 has different architecture needed for flash to work
Also note that Motorola Droid (the original one) has 550 mhz processor but it being armv7, runs flash quite well.. So its not a clock speed problem :(
You can Install Adobe Flash 10.1 for ARMV6. It would help play videos from youtube, facebook, Dailymotion but i could no play live streaming from espnstar.com
Multiupload.com - upload your files to multiple file hosting sites!
^^ does not work properly, certainly not videos from youtube.. It fcs as i mentioned in my previous post
