Help I'm getting so mad
So, first off, my Zmax pro will charge fine and I unplug it when it gets to 100 and the battery goes down pretty quick and my battery usually dies around 60 to 70 percent and if I try to turn it on it acts as if my phone is dead until I put it on the charger. Also, recently, when I put my phone on the charger I have to hold the charger a certain way and it charges so slowly. Also if I open Snapchat when my phone is at 75% or less my phone dies instantly. I am going crazy please help
I guess your battery not calibrate at all.Phone operate at minimum 3.4volt and maximum 4.2volt.Download Ampere app at google play and check the battery voltage.If the device reach 100% at 3.6-3.9,battery need calibrate.
If not works,send to factory to fix it.
If i remember back,this happen on my old tablet.Tab start shut down when battery below 60%,slow charging.I suspect your usb port at phone is broke.Seriously can harm your device if it broke.At least I had experinced this isuue at all.When usb port broke,charging become slow to full the battery thus battery calibrate self and you know that.
I just shared.I hope it helped you.
Regards:
LOL (Lots of Laugh)
