D
d3drocks
Guest
hello,
yesturday I bought my first android device. I have a Samsung Galaxy Tab.
I bought it from factory direct here in canada, which advertized it as a WiFi only edition of the tab, referbrished. the price was right, so I bought it. it works great, and I really dont have too much of an issue other than:
the tab is a referbrished one from Sprint. its a CDMA device. its been unlocked properly to not work with sprint anything (since sprint does not exsist in my country). it has a sprint boot up splash screen as well as shut down splash, sprint apps (which i cant delete, even with it being rooted), and a "system update" nagging about adding a sprint feature.
I honestly know nothing about android, and I need help. I would like debrand it (if possible), and remove the sprint software. if i do that tho, will I miss out on system updates? is there another way to update the device?
as i said, this is my first android device, so I'm in need of some help.
if anyone has any tips, or if i can even do this, or if i have to ship it to samsung, please let me know of everything i can do.
Edit:
I have rooted the device already, and have the superuser app installed, if that matters at all for this situation. I'd really like to remove all of the sprint software completely.
Edit:
